Ilikeshinythings
I'm not really familiar with the reflective properties of 5mm LEDs so my question is how would a 5mm LED work if it were used in conjunction with a larger reflector?
the Fenix E01 and Arc AAA both use tiny reflectors to achieve decent spill and a decent spot, but what would the outcome look like if the 5mm LED were used with, say, the reflector from a streamlight Strion, or an even larger reflector?
My guess is that since they are not that bright, there would be little side spill and a very tight spot--am I correct in assuming this?
