I just bought a Streamlight LiteBox (used, returned to vendor). I plugged in the charger that came with it (which was one of the chargers listed as compatible on the "charging box", and left it alone for over 24 hours.
While the red LED on the charging box had gone out, and the green LED on the charging box had come on, I received no light when I removed the light from the charging box and clicked the switch. I proceeded to shut off the light and examine the bulb (again), and detected no damage. I replaced the light in the charging box, and clicked the switch. I received a pale, wan beam.
I then shut off the light and left it alone for three more days. Same results.
Any thoughts? I'm guessing the possibility exists that the battery is shot for some reason. How would I check this? (I do have a digital multimeter {purchased from C. Crane Co., in case that helps anyone identify the meter's capabilities}, and a reasonable willingness to disassemble the light for testing purposes.)
If you have any other suggestions, please include methods for testing to see if that is the case.
I believe that since I purchased the light as a used item, Streamlight might be reluctant to honor the warranty (I'm not the original purchaser, after all). I do, however, still have the option of returning the light to the supplier from whom I purchased it, if I act within the next three weeks. I just hate to give up a LiteBox. Even if I need to purchase a new battery, I might consider it worth the money to keep the light.
Any and all help is appreciated.
