after handling a few arc LS's which included my own LSH-P, the first thing i noticed about the kroll was that when clicking it on, the light would sometimes blink off momentarily before coming back on again. another thing i noticed was that as the battery neared the end of its regulated life, pressing the kroll would cause the light output to flicker or fluctuate which is something that doesn't happen with a fresh battery. usually when clicked on at this point, the light would also be slightly more dim than just before the button latches on.
the quick fix for the above two problems is simply to tighten the tsp all the way down, as tight as you can. i believe the cause for the two problems i mentioned is due to the contact path being in the threads of the head and tsp.
basically if the tsp isn't tightened enough, the slight play in the threads would cause the electrical path to be broken momentarily because the tension required to depress the kroll might sometimes overcome the tension of the kroll's contact spring on the battery which otherwise keeps the electrical path in the threads closed. tightening the tsp all the way down would ensure the electrical path in the threads are always closed, with as little electrical resistance as possible.
as for the second problem mentioned, the slight fluctuations in the electrical resistance of the kroll whilst the switch is being depressed is usually exacerbated by a dying battery and the not-so-secure electrical path in the threads, which causes the fluctuations in light output when the switch is being operated in the final stages of the battery's regulated runtime. again, tightening the tsp as tight as possible would ensure the threads provide no fluctuations and as little electrical resistance as possible, and i've found this ensures that using the light in the final stages of the battery's life isn't as annoying as it once was. with the reduced electrical resistance, you might even get more runtime out of each battery. hope this helped! /ubbthreads/images/graemlins/wink.gif
