steinstern
- Joined
- Aug 5, 2009
- Messages
- 40
... would be an 2x AA flashlight with the batteries side by side.
i just can see a lot of pros and don´t understand why you can´t buy it yet (can you?!)
+ i would like the compact form factor much more than the usual 2x AA design
+ the possibility to run it on 1 AA in emergencies
+ becaus of the AA form factor you can put in a lot of different batteries (li-ion, alk, Nickel Zinc, lsd, generic nimh)
+ long runtime
+ AA format is perfect for travelling: it is cheap, you can get it everywhere, you can find it in a lot of different devices if you really need some (beats cr123 in this points; by the way: cr123 is very expensive and not very common here in europe)
+ more efficent than 1x AA due to higher voltage
(+) maybe it would be possible to produce a high capacity special li-ion battery with the section [not sure if that´s the right term] of a peanut-shell for longest runtimes in daily use (can´t describe it better due to my limited english skills)
what do you think?
maybe you could use 2 emitters next to each other in order to avoid a big flashlight head - wouldn´t it be more efficent (and brigher) to use two underdriven emitter instead of one or is this an error in reasoning?!
looking forward to any input!
+ long runtime
what do you think?
