Many of you have asked about the Lupine Flashlight.
Here it is , finally posted by Lupine on their own forum.
700 lumen, 90 minutes runtime. There will be 2 versions, including a 1400 lumen setup. I have tested the in progress 700 lumen version , and its a beauty! :twothumbs
Will post some more pictures later.
From Lupines Forum:
Housing:
140 mm length
45 mm diameter front
39 mm diameter back
260 gr total weight (incl. rechargeable 2.5Ah battery)
Features:
700 Lumens
Runtime on high: 1,5h
Runtime on low: does depand on your own favourite setting. max. 12h
Have a look on the attached programming sheme for the special features. The light does allow you to change the number of dimm levels and in 2-step the output on low beam.
Special settings like the stealth mode will disable the LED battery warning and the voltage check. The 2-step-flash setting does offer a disorientation mode.
You can even specify if the light does turn on low or high beam. E.g. Do I prefere to first have high beam, then disorientation mode, or the other way around?
Changing the settings is so simple and easy, it can even be done outdoor within a few seconds.
Original forumpost:
http://www.lupine.de/phpBB3/viewtopic.php?lang=en&f=7&t=2212
From Lupines Forum:
Housing:
140 mm length
39 mm diameter back
Features:
700 Lumens
Original forumpost:
