oregonshooter
- Joined
- Dec 19, 2005
- Messages
- 313
For you non-weapon type, bear with me.
I really like the TLR-1 as a weapon light! It has a great 10% hotspot for throw and nice spill, is very "white" and seems to be built like a tank.
I like to have a weapon mounted light on my "house gun(s)" which are my EDC Glock17 and Remy 870 14" SBS that I keep in the house at night.
The G17 is next to my night stand and is what I grab when things go "bump" in the night to investigate. If things go "crash, bang, boom!" then the G17 is what the wife uses to take cover with and call cops while I get the 870 with Surefire 618 forend.
I recently made two changes to my setup though for the following reasons...
1. I found that trying to grab my EDC light (6P w/Malkoff M60W & McC2S) I have a knack for knocking it off the night stand which adds more stress than I need when I hear a "bump" in the night.
2. Having your gun and light mounted in a setup that is the same every night helps immensely at that moment.
3. A weapon mounted light is a much better option over a non-mounted light. (I know what rule #2 is so don't derail the topic with it.)
What I did was mount my Safariland 6004 leg holster to the side of the bed, add a happy stick (33rnds of 9mm) and the TLR-1 for night time use.
The light and mag sit in the holster during the day and I switch them out before bed with my normal setup.
So here are some pics of that setup.
Next I found out that the TLR-1 is very very very bright at 03:00AM when your eyes are completely dilated and you shine it off a white wall even 10 yards away.
Anyone using a light with more than 60lums should test the flashback factor on their setup after just waking up. You will be amazed at how easy it is to have TOO MUCH LIGHT for those conditions.
The 120lum TLR-1 is so bright that when I hit the wall with it at 03:00AM the other night from 10 yards down the hallway, my eyes SLAMMED shut and I felt pain for a good 10 minutes.
So tonight I made a simple beam diffuser from a piece of Delrin that is press fit over the 1-1/16th bezel of the TLR-1 (just happens to be an odd size!) and is holding a 1" plastic lens from a Surefire FM34 diffuser that had a broken latch. You can make the diffuser out of any plastic 1" lens though by sand blasting it lightly. You can also use electrical tape instead of something fancy like I did, but the end result is a nice flood with a slight reduction in lumens but not pain in the eyes.
Try the 03:00AM trick sometime with your light and see if maybe a diffuser is not a good idea for the house light.
My solution below....
