[ QUOTE ]
Joe Talmadge said:
Norm,
I'm not sure what conclusions to draw from your test. Since it's 52+ minutes without the LEDs, what's the time with LEDs? 40-45 minutes? If so, an extra 7-12 minutes of incandescent light is very significant, I agree (although suspiciously high). But what I personally would be pushing for is an A2 where the LEDs turn off when the incandescent is on, since I'm still enamored of the dual-output 2-stage-switch light. I imagine this has been discussed before and there's some reason it wasn't done in the first place.
Joe
[/ QUOTE ]
Joe,
I remember seing a runtime chart (forget whose) that put the A2 with LEDS at 46-47 minutes, so 52 minutes is about 5 minutes more. However Brock's figures are 3 minutes at most which leaves a 2 minute discrepancy.
I only runtested without LEDs, never with. I got rid of them "permanently" because my injured thumbs found the 2 stage switch painful if I wanted to hold down the xenon for any length of time. The 2 minute discrepancy may be due to my giving extra "credit" to the A2 during its sun/moon alternating stage near the end of its regulated life.
Knowing that the Leds only steal 2-3 minutes from the xenon, coupled with an easier switch would probably have led me to keep the LEDs.
In terms of the KL4 beam, just as Don has chosen the longish PM6 bezel for a reflectored 5 watt, is it not possible to make a slightly longer KL4 bezel to accommodate a reflector, and even to mod a similarly lengthened E2E bezel or KL1 for a 5W E2E? Would creating a longer bezel from scratch be beyond the machining resources of individual modders?. OTOH, Don has created new PM6 parts that actually look better than the originals.
Finally, on the subject of 5W runtime, if W3V's become the norm rather than the exception, and their current average 34 lumens/watt (147.7Lu + 192Lu div2 =170 Lu div 5W = 34Lu)rises to say, 40Lu/watt, then running them at 1.5W or less to give 50-60 lumens on 2x123 should yield a runtime close to that of current 1 watters, with thermal issues moderated by the LED's efficiency at low wattage. Assuming that's correct, the thought of carrying 3-4 hours of 50-60 lumen light in an E2E-sized package is downright exciting.
Brightnorm
