I just put together 2 MCe's in a solid aluminum enclosure and powered by an external 8.4 VDC power source. The leds are driven by a Shark Buck 3A and the led dies are parallel configured and both leds are wired in series. I measured the amperage through the leds and reads 2.65 amps ( measured at driver output to leds) After about 20 minutes the enclosure is very hot but the leds are always giving out even full output. The leds are neutral white KE5 bins (370 lm). Is it normal that they put out that much heat and should I be concerned and perhaps put a fan in the enclosure?
