Illuminated
Hello all,
For anyone interested in building their own PR-base bi-pin lamp adapters, please read on...
The Carley #912 adapter is only rated to 1 amp, but has been used to about 1.2 amps.
I have used JB-Weld (regular type, 600-degree rated) and MOLEX # 16-102-103 C-Grid type pin receptacles to build an adapter that will handle more current. These pin receptacles are rated to 3 amps. The Newark Electronics stock number on these is 35C5018.
Another pin receptacle that looks even better is made by MILL-MAX, and the part number is 0295-015010627100 (Newark stock # 95F6581).
The Molex sockets are open and must be covered (I used heat shrink tubing) to prevent the epoxy from seeping inside and causing problems.
The Mill-Max receptacles are fully enclosed, and are designed to be placed into a PC-board hole and soldered in place. These are also offered in a range of sizes to accommodate different pin/wire sizes. They could be potted directly into an empty PR-base without the need for heat shrink. I will have to call Mill-Max to verify the current rating, but I suspect that it's at least 3 amps - hopefully higher.
FWIW, I've been using the Molex pin sockets in my PR-base adapter with lamps drawing near 2-amps for extended (1.25-hour) continuous runtimes, and have experienced no problems at all.
Higher current rated PR-base adapters will allow the use of unpotted bi-pin or stiff wire lead lamps such as those offered by Carley Lamps, Welch-Allyn, and even the "new" Mag-Charger Xenon lamp, in flashlights that only accept PR-based type lamps. Reflectors and heat, however, are a different subject...
Happy modding!
John
Happy modding!
John
