xinglong83
- Joined
- Sep 27, 2009
- Messages
- 14
Got some pictures to share
Will post beam shots as soon as it gets dark
Material: Grade 304 Stainless Steel
Battery Type: 1x CR123A
LED: Cree Q5
Size: Diameter 21mm, Length 84mm, Weight 86g
Circuit: High efficiency drive circuit with reverse polarity protection
Switch Type: Forward Clickie (momentary and constant on)
Brightness: Two levels of brightness (high & low)
Function: Easily adjust levels by turning head
Misc: Unit can tail stand and be used as area light with diffuser
Packaging: Comes in Aluminum gift box
Tail Switch: Stainless Steel
Diffuser: Can be purchased as an accessory
Runtime: High - 180 Lumen for 60 minutes, Low - 100 Lumen for 90 minutes.
LED: Cree Q5
