Dave Wright
A couple days ago, in another thread, I offered to post runtime and output results for a Madmax run on 1xAA. IMO this is a great light configuration. All it needs is an appropriately cut down optic to be my dream EDC. I don't have the technology to do that, so until then I'll just carry the Minimag 2xAA that I crudely cut down to be 1xAA. I call it "Madmaxine".
A few notes first. I'm not well equipped, meter-wise. I used the Gossen Pilot from my Leica D4 bag. My method was to slide the incident light curtain in front of the sensor and place the flashlight tight to the curtain. This captured most of the beam, essentially yielding a comparison of total lumen output (as opposed to the lux hotspot). The formula I used to translate the EV readings to lumens hasn't been independently verified. It's a somewhat educated guess.
Since I had the meter and formula anyway, you might be interested in the lumen results I got for some popular lights. The CMGs and Arc were tested with fresh alkaline cells. The dat2zip sandwiches were tested in a Minimag with stock tailcap and 2000 mAH Maha NiMH cells.
CMG Infinity: 2
CMG Infinity Ultra: 5
Arc AAA regular: 5
Badboy 400: 29
Madmax: 32
Badboy 400 w/ Q3L: 35
Madmax+ w/ Q3: 40
I then switched the Madmax+ w/ Q3 to my crude 1xAA body and ran the test. Here's how the light did. The format is minutes into the test followed by lumen output at that point.
0: 25
5: 23
10: 23
15 through 60: 20
65 through 90: 19
90 through 120: output fell steadily from 19 to 10 lumens
120 through 180: output fell steadily from 10 to 5 lumens
Test Abandoned
Note: In addition to the lumen figures, the light clearly "ran out of steam" at the 90 minute point. Up to then it was quite warm.
CONCLUSION: The Madmax sandwich can run effectively in the 1xAA configuration, 20 lumens for 90 minutes, which is IMO perfect for EDC use. Anyone care to answer the call? I see fame and fortune for the first company to put together a light with this output/runtime profile and a NX05 beam.
CMG Infinity: 2
Arc AAA regular: 5
Badboy 400: 29
Madmax: 32
Madmax+ w/ Q3: 40
0: 25
5: 23
10: 23
15 through 60: 20
65 through 90: 19
Test Abandoned
