what is the best driver for the two? direct drive mybe?
i must use driver ifi don't need a few modes?
how do i choose driver?
SSC P7 900 lumens 2800mA?
2800mA max circuitry output
some say the original driver is not the best for this SSC P7 900 lumens 2800mA
and
SSC P7 C-Bin LED Emitter with 21mm Heat Sink Base (3.6V~3.7V)
what do you say about :
Super Output SSC P7 LED Driver Board (Low/High/Middle,5.5V~15V) SKU:
Hightlight
and
Hightlight
Featurings:
- Current regulated at 3.0A
- Input voltage 5.5V-15V, (no more than 12V would be the best option for protection of LED board according to accurate test)
- Buck Voltage Current Regulated circuit
- Gives 1+ hour current regulated (3.0A) output with four Eneloop AA
- Gives 3+ hours current regulated (3.0A) output with two protected KD 18650
-Gives 90%~95% efficient output
- Measures 19mm in diameter, and 8mm in height
- Multi-Mode: Low(5%)/High(100%)/Middle(35%)
- Designed for SSC P7 LED for maximum output 300lumen-900lumens(C bin)
- 1xLED+, 1xLED-
- Prewired, ready to use
Highlights:
-PWM light-adjusting function (122Hz/244Hz)
-Auto-alarm towards high temperature,then switch to low mode automatically
-Inner system for Li-ion Battery protection (never over discharge/charge)
-Be compatible to CREE/N2---P4---Q5---R2---R4---MC-E;SSC/P4—P7;
Guarantee:
-All from genuine original factory
-Undergoing accurate electronic test before package
-With free registered mail and ensure whole shipment term within 10 days worldwidely
- TEST:
Input Voltage and Current: (Average Test )
Voltage
Low
Mid
High
5.5V
0.20A
1.05A
2.00A
7.2V
0.17A
0.85A
1.60A
9.0V
0.15A
0.70A
1.35A
11.1V
0.13A
0.60A
1.15A
13.2V
0.13A
0.53A
1.00A
Output Voltage:
2.8A(High)~ 1.38A(Middle)~0.25A(Low) --at any voltage level from 5.5V to 13.2V---Current regulated
Caution: No more than 3 D-size Li-ion Batteries (4.0V~12.0V) for protection this LED board
thank you
