fyrstormer
Banned
Let's see if there's a market for a 375nm UV drop-in for the Ti-AAA, since Peter was nice enough to make the driver replaceable.
1. fyrstormer
1. fyrstormer
Wow, this is a resounding failure. Nobody at all is interested in this?
You can buy several models of McGizmos with UV light engines installed, and they all use sapphire lenses. I have a couple of spare sapphire lenses, so I held one in front of my UV Mule and there was a noticeable, but not significant, drop in the fluorescence of my bath towel, most likely due to sapphire's 95% transmission rate.1. I wonder if the sapphire window is UV transparent
2. The interchangeable modules may not be so easy to tell apart, and the UV light is potentially eye-damaging. Frankly if I had a UV light I'd want it to be festooned with laser warning stickers or something like that.
3. Arc makes a perfectly good UV light in the aluminum AAA format. I'm tempted to buy one (wish it were available with a purple battery tube) but don't know what I'd do with it.
I have a McGizmo Sapphire on my keys. I would be interested in a UV version, but I'd need a second host as the light is too useful as is to swap the emitter.
I am interested in the UV drop-in. I would also like to have a red (for night vision retention) and a white optimized for throw. Since the Sapphire platform was designed to accommodate drop-ins, it would be even more valuable if a few other drop-in options were available. I rarely use UV so switching the drop-in when it is needed is a good solution.
