I snagged one of PFs SST-90 evaluation pieces last month
and have been waiting for a purpose designed Mag heatsink
Member Britelumens, brought some out here
So now I have all the pieces, I threw everything together
All the necessary components
BTW the excellent host came from Wquiles :thumbsup:
The most important components
I removed the emitter from the star and managed to singe the emitter
a little, you can just about see the carbon around the metal surround
Everything assembled
To keep things simple, I chose to direct drive the emitter with an IMR 26500.
I had a KD OP Mag reflector on hand which I widened the opening using
a Dremel. This managed to flake some of the coating off around the openning Pt2
It lives !!!!
Not bad for a hack job
Important note .... I made the mistake of soldering the wires to the emitter
and then sticking the emitter to the heatsink first. I then realised
that once this was done there was no way I could solder the emitter
wires to the Mag switch inside the Mag body. This meant that I had
to solder on another set of wires to the switch and then solder that to
the emitter wires Pt3
I would have rather prefered to have no joints
The important question everyone wants to know is, how bright is this sucker?
With no way of taking actual measurements and just using my eye,
it is a tad brighter than my P7 Mag DD, this is from indoors on a white wall.
I will try and get some outdoor beamshots tomorrow.
The beam that this emitter produces, I can only describe as a HUGE hotspot
with tons of spill. No dark crosses or donuts but up close to a whitewall
you do see a very slight clover leaf.
There was some debate in Britelumens heatsink sales thread as to whether
his heatsink pedestal was high enough to focus correctly. I can confirm
that the heatsink will allow correct focus if you turn the Mag head all the
way down.
It lives !!!!
way down.
