4 x AA eneloops on TK40 on turbo
headophile
metro manila, philippines
as the title states, will the batteries be able to handle it?
if so, how long is the runtime?
if not, will the high-current aa batteries used in mag85s (like titanium power max or cbp elite series) be safely applicable in this situation?
i'd really like to run the TK40 in 4 x aa configuration.
thanks!
headophile
any knowledgeable enough people care to reply?
even theoretical answers with exact amperage figures (and other things i'm probably failing to consider at this point) would suffice.
also, i won't hold you liable if something goes horribly wrong :D
ubetit
Lewis Center, OH
The batteries in the TK 40 are 4x4 in a series-parallel setup. The extra 4 batteries just increase runtime. All the rules that apply with 8 cells should apply with 4 cells with less runtime. I used Turbo fo 25 minutes the other night while cleaning out a dryer duct outside and it never overheated. I run eneloops. Not sure i'd use alkalines in this way though.
headophile
thanks for the reply and that's great to know!
i was just reading the tk40 manual and fenix doesn't recommend using turbo on 4 x aa. i guess that only applies to alkaline primaries then.
how long would be the total runtime on turbo? has your light died yet?
LEDninja
Hamilton Canada
The TK40 requires ~3A.
Some batteries cannot produce 3A.
The Eneloop can.
The Eneloop produce 2AH. The TK40 requires 3A. 2AH/3A=2/3H=40 minutes. YMMV.
