New XP-G R5 flashlights rated at "139lumen/90minutes"
jalbam
Spain
Hi!
I noticed that KD is selling two new flashlights with the new CREE XP-G R5. But why does they have so few lumens?
They are rated at 139 lumens, which is very low. Even a XP-E R2 seems brighter (usally rated at 250). How can this be true?
May be XP-E R2 at 250 are overrated, but I guess they do the same with XP-G R5.
I thought ordering one of them, but they doesn't seem really bright and the battery life is not so long neither.
These are the two flashlights which I found:
http://www.kaidomain.com/ProductDetails.aspx?ProductId=10068
http://www.kaidomain.com/ProductDetails.aspx?ProductId=10066
Thank you in advance.
Cheers,
Joan.
Gunner12
Bay Area, CA
LEDs can be driven at different currents for different outputs, which could explain the ratings. But the runtimes do still seem short.
old4570
Melbourne - Australia
3.7V ~ 1540mA,4.2V~2130mA,
LED
1.NO.:XPGWHT-LE-0000-00H51
2.3.0V~3.75V,
3.0V-350mA/h-139LM
3.2V-700mA/h
3.7V-1000mA/h-148LM
Im not sure they have a clue !
Marduke
Huntsville, AL
Who would believe a single one of those values to begin with? Especially from the absolute worst store to deal with...
jalbam
Spain
So, if it's a real XP-G R5 what would be the highest lumen rate? Would be better than a XP-E R2?
Marduke
Huntsville, AL
That would depend on the drive currents being compared. You can make a "real XP-G" light that is dimmer than a firefly if you want.
jalbam
Spain
Then I don't understand, if they have the newest stuff from CREE, why don't they use it better?:shrug:
Marduke
Huntsville, AL
Well, the specs are totally imaginary to begin with, so...
It would not surprise me of it wasn't even an XP-G.
moviles
LED
2.3.0V~3.75V,
3.0V-350mA/h-139LM
3.2V-700mA/h
3.7V-1000mA/h-148LM
cree XP-G flux bin R5: 139-148 lumens @350ma
they say current draw are 2.130 amp at 4.2v, it must give more than 300 lumens
XP-G:
XP-E flashlight
Marduke
Huntsville, AL
Well, after they scammed CPF a number of years ago and changed names to avoid the bad plublicity, and were bad enough for eBay to ban them (which is impressive).... :whistle:
Nitroz
Monroe
Something just does not add up here. If it was being pushed at full power a 90 minute runtime would make since, but the lumen to runtime ratio does not make since. They don't have a clue on this one.
That's one of those buy and try lights, and even then you don't know if you get what is advertised. But you get what you pay for as they say.
Nitroz
Monroe
I didn't know that.
I had to threaten not to use them ever again just to get some 10mm XP-E boards after they sent me XR-E boards. This was after numerous email exchanges with them and they claimed they could not see the pictures. I eventually got fed up with this and said nevermind and I would just never use them again, and then they decide to play nice, all this for a 2.50 item.:shakehead
Regardless, I still don't have the boards yet. Never again.
BentHeadTX
A very strange dark place
I bought 12 "Sanyo Eneloop" AA batteries from them. They were fakes so I recycled them so not to contaminate my real Eneloops. I'm staying away from that site since I don't like flipping coins to see if I get the product and it is what it says it is.
wesinator
Louisville, Kentucky
Well, i think they do have the XP-G led because you can barely make out the 4 lines in it compared to the 3 in the XP-E. Someone must have just had a long night at KD whent they were filling in the specs.
LEDninja
Hamilton Canada
Fellas read the specs section.
Direct Drive
High/Mid/Low/Strobe/SOS
:crackup::crackup::crackup:
old4570 & moviles nailed the 139 lumen bit.
They just copied the # from the spec sheet the way those P7 torch makers copied 900 lumens from the SSC spec sheet.
The 90 minutes runtime is reasonable for DD a XP-G with a 18650.
old4570
If its 139 per 350mA then it might really pump ..
Just depends on the driver used .. My guess is its a 1A 5 mode driver ..
Which one ??
Again , just slinging mud ATM !
Some one buy one and let us know ! :candle:
