This is probably going to seem like small stuff to most of you guys, but I'm proud of it. Here is what I did:
1. I unscrewed the top of my 2AA Mini-Mag like I was gonna put it in "candle mode."
2. I took off the little black plate that held the current light bulb.
3. I took the light bulb out.
4. I put a red 5mm LED in instead of the old bulb. Red because that is the color of my mag.
5. I put the plate back on.
6. I took it back off, and trimmed the longer wire of the LED because it was too long to let the other wire reach the hole. /ubbthreads/images/graemlins/twak.gif
7. I put it back in.
8. I took it back out, and put it back in the other way because it was in backwards. /ubbthreads/images/graemlins/twak.gif
Whoo-hooo! It lit up!/ubbthreads/images/graemlins/buttrock.gif I made my first mod before I turned 16, how cool is that? Not much I know, but I like it. I had to widen the hole in the reflector with my advanced machinery (my pocket knife/ubbthreads/images/graemlins/thumbsup.gif) so the LED would fit because it was bigger than the original bulb. Now I have a focusable 2AA LED light!
Beamshots! They are with my mod on the left and my ARC AAA standard on the right. The first is with my mod on tight focus, the second on wide focus. Both flashlights have fresh Duracell batteries.
EDIT: I just saw how dark these pictures are. I will try to bighten them up, but for now you just have to turn up the brightness on you computer if you even want to see anything in the second picture. Let it suffice for now to say that I could barely see the ARC.
I call it... the Mighty Mouse. /ubbthreads/images/graemlins/grin.gif
