I'm assembling a SSC P7 direct drive w/3 AA NiMh should I use a resistor or diode or will the internal resistance of the switch be enough.
If I need a resistor my guess is that I would use something around 1 ohm at 10W. Has anyone found one small enough to fit in a mag D
If I use a diode to protect from reverse voltage and add a slight voltage drop what are the ones that are commonly or successfully used?
