this_is_nascar
Tonight after I get home, I want to perform a simple test to see how much of the cell the L4 really uses. I'm going to run an L4 until it drops into moon-mode, the put one of those cell in an ARC-LSH and the other in a McLux. I will note which cell goes into which light, since there's still an unanswered question as too the cell closest to the tailcap having a bit more juice in it after exhaustion. Maybe what I'll do is perform the test twice and each time change the host cells when put into the LSH and McLux. For example, in the 1st test, the McLux will get the cell closest to the bezel, the LSH will get the cell closest to the tailcap. For the 2nd test, I"ll reverse that cell configuration.
What I'm trying to prove in these tests is whether or not the LSH or McLux can draw more useful juice from the cells, after the L4 thinks he's drained them as much as possible.
