Question Regarding SF use with AW RCR123A's and AW 18650
FearlessNKY
Kentucky
Can anyone tell me when using AW RCR123A's or AW 18650's with a SF 6PL with a Malkoff M60L, does the light dim as the batteries charge is used up, or does it cut off completely all of a sudden?
(I've used some protected RCR123A's 3Volt with a SF G2L, and while it works well, I hate that the light cut out when the charge drops.)
I thank you in advance for your info!
Mike
seale_navy
previously Newcastle, UK
I am not sure how to answer this as I never own a malkoff before.
Through my reading, I think that it will dim for a very short period and then cut off.
probably the more advance ppl in this forum will answer your query soon enough
Owen
AL
The 2xR123 will provide constant brightness throughout the runtime, and cut off suddenly as the batteries go into protection mode.
The 1x18650(or 1x17670 in a unmodified 6PL) will provide constant brightness for however long the battery voltage stays above the voltage required by the buck circuit to maintain regulation, and then it will begin to gradually dim.
gswitter
California
...and it will eventually be cut off by the protection circuit.
ionizedsky
Malkoff M60 & M30 Runtimes,etc <--Check this thread lots of good info on runtimes.
Just FYI as some pointed out. Factory Surefire 2x123 bodies WILL NOT FIT 18650 Cells, however a 17670 will fit.
Although if you want to run a Surefire with a Malkoff Module M60/M30 (whatever you choose) with the longest run time you'll want to run AW 18650 2600Mah cells but you will need to have the body bored. See next link for help with that. 18mm Bore Services: Surefire® P, C, and Z series
Oh and :welcome: Your finally home :nana:
https://www.candlepowerforums.com/threads/194879
FearlessNKY
Kentucky
I'd like to say thanks to everyone for the warm welcome, and I really appreciate the info!!!
Based on the info you guys provided I just ordered a Bored 6P Body that accepts 18650's, as I feel this is going to work out perfectly for my application. :thumbsup:...I'm needing the extended run time and some "warning" before my light suddenly goes dead. So my torch will end being a Bored 6P with a Malkoff M60L that runs on 18650's..... can't wait!
Thanks again!
