A dual, or triple side shooter like what McGizmo did, but using the XP-E should give very good absolute output, as well as throw. The triple shooter can be mounted on a triangular shaped heat pipe, which would do quite well in taking away the heat from the 3 emitters.
Taking it one step further, 5 emitters mounted in a cube, (4 sides and one firing forward for spill) would be quite something too!
Any thought or comments? Has anyone else tried this with the newer generation emitters?
http://dmcleish.com/CPF/McRee-XR-E/index.html
