Pretty much all you need to know is the drive current and from there you can get a rough estimate range of how many lumens the light is putting out at the emitter.
I regret that finding a lot of information as well as pictures of Peak lights is very difficult. I haven't seen a picture of an El Cap yet. Hence the main reason Peak lights aren't as popular as they could/should be.
+1
When looking at lights, I just want to know what the LED current is so I can calculate lumens. Moving from a L2D Q5 driven at 700mA through a Q5 or 180 LED lumens to a Turbo AA2 which is also driven at 700mA, I calculate 270 lumens at the LED.
I know Peak is working on a multi-mode tail switch and I look forward to 2 or 3 levels. If the El Capitan can be switched, then all I need to know is the drive level to the LED. Since I want a single AA light driven from a single 2000mAH Eneloop battery to have 90 minutes of runtime, I can spec a El Capitan to meet that requirement. Another interesting thing is the optic, once a narrow optic is available...the XP-G can have decent throw with a small head. The Turbo AA2 has great throw but the head is rather large and heavy so...
Maybe Curt and put up a chart with each drive level current to the LED? Then throw how much current it pulls from a NiMH and 14500 li-ion cell? It would be simple to match the drive level to lumens at the LED and calculate run times from the battery.
Once the multi-level switch becomes available, different optics to change the beam shape and those charts are in effect, I can custom build the El Capitan to what I want.
I am aware that LED lumens are not equal to out the front lumens but at least I have a solid number to calculate from. Optics are nice since they give a percentage (78 to 87%) of lumen loss and you can calculate the lumen loss through the lens (or window) For now, I would say a XP-G driven at 300mA is 126.4 LED lumens then calculate 83% for the optic (105 lumens) and take off 2% for the window for around 100 lumens OTF. Choose the optic to give the beam width/spill and order that puppy!
For now, I would say 300mA to the emitter, 126 LED lumens and a narrow optic with 90 minutes of run time and 120/25/3 lumen output levels would work for me. I'll take 2 or 3 of those in HA-III aluminum please!
