Thank you! Do you know how many amps a P7 draws? I have a C bin and a D bin, not sure if that matters...
Depends what you're powering it with. Off a good regulated 4.5V power supply, I guess it'd draw >20A for a few milliseconds, then
-- off a 3V or so supply, maybe a couple 100 mA. The rated maximum is 2.8A, which will happen around 3.5V. You can find typical I-V curves in the datasheet.
The C/D bin is a luminous flux bin, and tells how bright the LED is
at a specific current; nothing to do with input power -- the Vf bin is what tells you what voltage, at a given current, and therefore what current from a decently steady voltage source (at least unless/until the LED heats up and goes into thermal runaway...). But on alkalines, none of that matters, because they can't really deliver 3A at
any voltage for very long. Initial current could be as high as 3A, though I'd be surprised if it was over, but it'll quickly sag to a current level at which the batteries can maintain their voltage, and gradually roll off as the batteries die.
If you
must have a DD KOH P7, I'd strongly recommend 4D instead of 3D -- you'll get a little more overdrive at the beginning, but if you just put fresh batteries in, the light's probably cool enough, and a Mag has enough mass, that you'll be fine for the first ~10 minutes. After that, it'll be underdriven anyway, but with 4 cells instead of 3, there'll be usable light for much longer -- brighter than a comparable single-die for at least 4 hours, IIRC.
And then, when you get bored with that light (and long for flat regulation), you can drop in an 8xAMC7135 LDO driver, and simultaneously stop the overdrive on startup and gain the ability to run regulated for ~3 hours on D NiMH.
OTOH, some are quite happy with their P7s DD on 3xNiMH D, so if the size is important, a 3D will work out too when you move up to rechargeables. It's just gonna do really really bad on KOH meanwhile.
