old4570
Here it is , the Solarforce L2i .
Reverse tail clicky , 3xAAA Format .
Mine came with a single mode Low voltage Pill .
Now you can run , 1xAA , 3xAAA , CR123A , 14500 , 18500 or any other battery from 1.5v to 4.2v that you can stuff in there .
The 3xAAA carrier seems to be of very high quality , and I have nothing negative to report .
Typical Solarforce quality overall , and Im very pleased with it .
Anyhow , some performance figures :
1xAA Performance Single Mode Pill
Rechargeables
MP2800mAh 2.03A / 3900Lux
Ultracell 2500mAh 1.9A / 3900Lux
Inca 2000mAh 1.7A / 3720Lux
Sony 2000mAh 1.83A / 3240Lux
Eveready 1.77A / 3320Lux
Tevion 2500mAh 1.75A / 3200Lux
Non rechargeable
Eveready General Purpose 0.9A / 1810Lux
Ultracharge 0.9A / 1830Lux
Varta High Energy 1.9A / 3700Lux
Duracell Alkaline 2.05A / 3600Lux
Coles Alkaline 2.1A / 4000Lux
3xAAA
Duracell 0.98A / 8900Lux
AW RCR123A 0.89A / 9000Lux
Since I own the 3 mode low voltage pill , lets give that a try as well .
3 Mode Low Voltage Pill
1xAA Rechargeable
Ultracell - Hi 1.6A / 3700Lux - Med 0.75A / 1600Lux - Lo 0.19A / 370Lux
MP - Hi 1.7A / 3700Lux - Med 0.78A / 1670Lux - Lo 0.19A / 360Lux
Eveready - Hi 1.3A / 3300Lux - Med 0.58A / 1490Lux - Lo 0.15A / 330Lux
Sony - Hi 1.43A / 3000Lux - Med 0.66A / 1420Lux - Lo 0.16A / 300Lux
Non rechargeable
Ultracharge - Hi 0.67A / 1600Lux - Med 0.32A / 770Lux - Lo 0.09A / 170Lux
Eveready GP - Hi 0.7A / 1700Lux - Med 0.33A / 790Lux - Lo 0.1A / 180Lux
Varta - Hi 1.59A / 3400Lux - Med 0.69A / 1510Lux - Lo 0.18A / 330Lux
Coles Alkaline - Hi 1.68A / 4000Lux - Med 0.76A / 1750Lux - Lo 0.18A / 380Lux
Duracell Alkaline - Hi 1.53A / 3300Lux - Med 0.72A / 1500Lux - Lo 0.18A / 340Lux
3xAAA
Duracell - Hi 0.83A / 9000Lux - Med 0.36A / 3890Lux - Lo 0.09A / 890Lux
Ultracell - Hi 0.96A / 9600Lux - Med 0.41A / 4000Lux - Lo 0.09A / 920Lux
AW RCR123A - Hi 0.88A / 9600Lux - Med 0.38A / 4000Lux - Lo 0.09A / 920Lux
Ive been playing with the light for a few days now and I must admit that I do like it very much . It just has to be one of the better 3xAAA format lights available , and it is very easily adaptable to other batteries .
Ive run RCR123A with my own home made battery adapter , 1xAA with a spacer , as well as 3xAAA . And there is really nothing negative to report , its all good .
If your looking for a Survival/Multi battery capable light , then you really need to take a look at the Solarforce L2i , I would highly recommend the low voltage multi mode drop in , but if simplicity is what you need , then the single mode low voltage pill will not disappoint .
Now if you must know , 10,000Lux is around 200Lumens , so feel free to do a little math .
:laughing:
