Sold/Expired SOLD: XPE R2 Stainless Steel N cell/10280 3 level Twisty
ma_sha1
CT, USA
Asking price: $49,
****X-Mas Holiday Sale $43
$41 $39, $29 Last Price drop before withdraw******
Add $4 to cover PP fee & shipping.
CANUS only.
This is a New Stainless N-Cell flashlight I made from custom cut down from of a longer AAA cell Stainless Flash light.
Tail end is covered with carbon Fiber,has a small filing mark next to the bottom but too small to show in photo, has a gold ring in the middle of the body. it's beautiful looking & one of a kind, there is no second one on CPF! Great item for those who loves stainless steel flashlight!
If you've seen my FS threads, you'll know I only hand make each light one time! There won't be a second one, no need to PM me to make another if you are not the buyer.
"Man can never step into same river twice"
-Heraclitus of Ephesus, Greek philosopher, 540-480BC
Runs on regular N cell or NiMn rechargeable N cell, beautiful beam too.
Cutting & grinding stainless steel is really hard to do, lot of hard work went into this.
This light is also capable of Running 10280, you just need to solder a drop of solder to the positive contact board in the head if you want to run 10280. As 10280 is slight shorter than N-Cell.
The picture from my point & shoot camera doesn't do it justice.
Mfg. Rated Specs before custom cut down:
Emitter : Cree XPE R2-WC
Voltage Input: 0.8~4.2, 4.2V max
Modes: 3 Modes
Hi 150LM 1200mA > Low 80LM 900mA > SOS 120LM 400mA
Brightness: 150 lumens maximum brightness (manufactuer rated)
Lens: Coated Glass Lens
Reflector:
Aluminum SMO Reflector
This light is capable of Running 10280, you just need to drop a drop of solder to the positive contact board in the head if you want to run 10280. As it's slight shorter than N-Cell.
bstrickler
Tucson, Arizona
Re: FS: XPE R2 Stainless Steel N cell/10280 Flashlight 3 level Twisty
That kind of current draw will destroy a 10280 in no time. Looks like it needs a new driver, if you ever plan to run it with an N-cell or a 10280.
ma_sha1
CT, USA
It's xxxxFire manufacture rating, they are not accurate.
I have no idea what current it is with N cell or 10280,
but I can tell it is less than if you'd run 10280 direct drive.
On my key chain light, I run direct drive with 10280 & XPE,
it's been several month, nothing has been damaged.
10280 & 10180 is so tiny, they do not act the same as bigger Li-ion.
Plenty of others have done the same, for example:
Draco turbo mode is 10280 direct drive
Wee hi mode is 10180 direct drive.
stinky
you do some very nice work
ma_sha1
CT, USA
Thanks!
kiely23+
Germany
no international shipping... :mecry:
ma_sha1
CT, USA
I am really sorry, I wish I could do Int. Shipping.
Due to my limitations, I can only do PP pick-up at my door as my day job is too demanding to make post office trips. Unfortunately, the custom etc. could not be done via. PP pick-up.
Sorry.
ma_sha1
CT, USA
Re: **Reduced**: XPE R2 Stainless Steel N cell/10280 Flashlight 3 level Twisty
Price reduced. Now just $41
ma_sha1
CT, USA
Price Drop to $39
Merry Christmas!
ma_sha1
CT, USA
Re: *Final Reduction*: XPE R2 Stainless Steel N cell/10280 Flashlight 3 level Twisty
Final Price drop to $35
ma_sha1
CT, USA
Re: Now $35: XPE R2 Stainless Steel N cell/10280 Flashlight 3 level Twisty
Bumpti bump, Where are the Stainless Steel or N-Cell Lovers in the US?
ma_sha1
CT, USA
last Price drop before withdraw: $29
rebelbayou
Do you have any idea how long the run time might be? Also, is it more of a thrower or flood? Thanks.
ma_sha1
CT, USA
Re: Last drop before withdraw $29: XPE R2 Stainless Steel N cell/10280 3 level Twisty
Estimated run time about 1/2 hr with 500mah NiMN N cell
You can get these high capacity N-cell here for $1.99:
http://www.interstatebatteries.com/cs_eStore/Search.aspx/Redicom?dsNavigation=Nrc~id-3,N~4294609628
With 10280 Li-ion (Battery used by Draco, ~180mAh), it'll be slightly brighter but with shorter run time.
Small XPE R2 die combined with SMO reflector, making this light more of a mini thrower than flood.
For tiny lights, it's much harder to produce throw than to make flood, thus, making this tiny light more special.
rebelbayou
Thanks for the quick reply. My gears are turning trying to find an excuse to justify buying another light after receiving 5 or 6 for Christmas! But, I am a lover of SS and mini throwers, and as you stated, not much choice with that combination.
ma_sha1
CT, USA
The trick is to sell some flashlights at CPFMP, that way, you'll have plenty
of funds to play with new lights without feeling guilty :devil:
rebelbayou
Thats one option for sure. Hmm....I'll have to look through my current stable when I go home for lunch and try to make a decision...:confused:
Bullzeyebill
CA
What is the diameter and OAL of this mod?
Bill
