Does the Eagletac T20 outthrow the LX2? The RRT-1?
I don't have or seen the Eagletac T20, but if the reflector is 30~36mm with an R2 or XP-E I can see it out throw the LX2.
My L1 and E1b bezel can be screwed in to provide more of an intense hotspot or less spot with more spill. This is common with all Cremator Milky L1 builds, but the Milky variants use a Q5 or R2. Mine have an XP-G R4, but Milky is working on my R2 version now.
My goal is to have a shoot out for throw and OTF lumens with the following:
- Milky L1 R2 direct drive
- Nailbender L1 XP-G R4 direct drive
- E1b w/1.4A driver put together by Kramer5150
I already have the OTF numbers for the E1b and Nailbender L1 XP-G, but I need Milky to finish the R2 for MrGmans IS test.
Plus, I want to compare the throw, spill, and general beam pattern on these.
You should really crack that bezel open and see for yourself if the extra tight spot (in theory more throw) is worth the spill you will loose. I have found that I like the wider spot with more generous spill more. It even appears brighter this way too. So, before you have your LX2 modified play around with the Tir Optic and see how you like it.
Regards,
bigC
