I excitedly received my Quark 123-2 in the mail today. Unfortunately I discovered that it apparently is mechanically defective. It initially appeared to work fine, but when I turned the barrel around to reverse the clip it no longer worked at all. The problem is the thread depth on the "non-clip" end of the barrel is shorter than the thread depth on the clip end. When I screw the clicky switch/tail cap onto the non-clip end (yes I screwed it all the way to the stop) it does not make electrical contact. When I removed the switch/tail cap and used a paper clip the unit "worked" fine. Re-reversing the barrel caused the light to work again. The clip end is 9.55 mm from end of barrel to stop. The non-clip end is 8.99 mm from barrel end to stop. The problem is the threaded section of the non-clip end is too short. I have close up pictures with a caliper, but this forum apparently won't let me post attachments <Update: See photos further in this thread. -BB> . When I try to insert an image, it asks me for a URL.
For the working case, the instructions say to rotate the bezel half a turn to engage the "moonlight" mode. In my case if the bezel is anything other than "hard tight" then the light is in the moonlight track. To reliably insure I get full power I have to turned the bezel down to the stop, and then give it some extra torque. This may also be due to the fact that in the "working" mode the bezel gets the "short end of the stick" so to speak.
Bruce Bowen
Bruce Bowen
