I fired up my newly build 3D Mag running CTA D-cell batteries and everything was fine for the first ~5 seconds. Then the light started turning blue and the emitter went dark.
Before anyone asks, yes it was installed on a heatsink AND the heatsink was installed in the flashlight. And yes, I used thermal adhesive to install the emitter. This isn't my first build just my first DD build.
I've read about plenty of people running the SST-90 direct drive using everything from IMR cells, emoli, NiMh, etc. But I have yet to see anyone fry one of these emitters. Could it be that these CTA cells did not experience voltage sag when powering this emitter? The initial voltage was 4.24 V. Did I get a bad emitter? Is there anything that can be done to fix it, can't image what that would be?
POSTMORTUM:
I did not get good thermal contact between the emitter and the heatsink. When using the Britelumens heatsink, IF your wires are not exactly in the right location and oriented exactly the right direction it will make installing the emitter more difficult. In this case I THOUGHT the emitter was pressed fully into the pocket on the heatsink. As it turns out, I did not get the emitter pressed COMPLETELY down into the recess and make COMPLETE contact with the thermal epoxy. Cause of death: thermal overload.
POSTMORTUM:
