Yeah i was talking about an xre R2 vs a xpg R5.
So if im running this on say one single cr123 i should get more lumen with the xpg R5 and better run times but as i know less throw?.
Is that correct.
Its correct that in exactly the same light the R5-XPG should produce a higher overall lumen output than the R2-XRE.
Throw is more complicated because it depends a lot on the type of secondary optic that is used to project the beam.
By secondary optic I mean something like a reflector or a Fraen optic, for example.
These need to be well matched to the light source in order to harness all the light being emitted (ie. the correct focal length is important.)
The design of the optic will also determine the nature of the beam, whether it is floody or more of a spot-like beam for longer distance projection.
I am sure that a secondary optic can be designed specifically for the R5-XPG with either flood or throw in mind.
For instance I have read in the marketplace that the company called Dereelight have now changed their light source in the DBS V3 from an XRE to an XPG and redesigned their reflector for this specifically.
The Dereelight DBS V3 is renowned for throwing well and in the marketplace it is claimed that this change does not affect the throw adversely.
In smaller lights with small reflectors, I think its quite likely that the XRE will out-throw the XPG, but its unlikely to be by an amount that is significant enough to affect the application that the light was intended to be used for.
The Haiku is a good example of this.
In the McGizmo forum, Don (McGizmo) has replaced the XRE in his Haiku with an XPG-R5 for a new wave of Haikus with accompanying new reflectors.
He has measured a greater overall output but slightly less throw in these soon-to-be released Haiku-XPGs.
As the Haiku was not intended to throw very long distances, this slight sacrifice in throw is not important and the overall higher output is probably
more advantageous.
I hope this answers your question.
