Hello *@*,
recently I saw a bunch of posts dealing with the matter whether or not to leave the thin plastic lens protection film on the ARC LS optics.
If you want your ARC LS to be as /ubbthreads/images/graemlins/cool.gif bright /ubbthreads/images/graemlins/cool.gif as possible my advice is: *DO* take it off. The reasons for this are simple physics:
When light (or for that matter any electromagnetic radiation) is incident upon the boundary between two media, some of the energy is reflected and some undergoes refraction and is transmitted. There are several physical laws that govern the direction, amplitude, and phase of the reflected electromagnetic energy, but if one of the media is air, which has an index of refraction close to 1, then at normal incidence (the light propagates perpendicular to the surface of the glass) the reflectance for each surface is given by:
R = [(n-1)/(n+1)]2
where n is the index of refraction of the glass.
For glass with an index of refraction of 1.5 and negligible absorption, approximately 92% of the light will be transmitted though the glass and approximately 8% will be reflected (4% from each glass/air surface).
In multi-element systems, losing 4% of the incident energy at each surface can result in a significant overall loss of energy. For example, the total loss for ten common glass optics (n = 1.5) is over 60%. Optics with higher indices of refraction will suffer even larger reflection losses. Losses are also greater at higher angles of incidence. To prevent reflection losses, anti-reflection coatings that significantly reduce the fraction of incident energy reflected from each surface must be applied to each surface.
I don't know the exact index of refraction of the plastic film on the ARC LS lens but I suspect it to be even higher than that of glass, so the loss of light will probably be >8%. The ARC LS is already losing a significant amount of light energy in the optics mounted on the Luxeon Star, so away with the evil lens film I say. /ubbthreads/images/graemlins/twak.gif
-Connor /ubbthreads/images/graemlins/wink2.gif
R = [(n-1)/(n+1)]2
