Angryfox
Results 1 to 15 of 15
Thread: Do I NEED a new Fenix PD20 R2?
    Flashaholic* JWRitchie76's Avatar
    Jun 2009
    Jo Daviess Co, IL
    Default Do I NEED a new Fenix PD20 R2?
    This is the question! I used to own the old PD20 w/ Q5 emitter and I sold it thinking I would upgrade to a 2x 123 style light. Well I really miss that little light. The only negative thing I can say about it is it lacks momentary on but I can get over that. Anyhow I came across a really good deal on a brand new PD20 R2 version and I'm having OCD trying to figure out how bad I want it. I like the fact it now comes with a clip but is the clip very stout? Is there something else in this lights class that I should check out before I pull the trigger? Decisions, decisions............
    Default Re: Do I NEED a new Fenix PD20 R2?
    Get it, the clips are strong. If your already having OCD about it you might as well relieve yourself and get it.
    My flashlight collection HERE
    Quote Originally Posted by signalprick View Post
    Yes, yes you do!
    What? We're telling you what you want to hear right?
    Flashaholic* Henk_Lu's Avatar
    Oct 2007
    Golden Cage
    The PD20 is a very nice light, I have the Q5 with an SMO reflector. To my gusto, it doesn't have enough spill, but I guess that could have been adjusted by getting the OP version, which wasn't available the time I got it. I don't know if the R2 version has an OP, SMO or if both versions are available.
    So, depending on what beam profile you look for, I can recommend the PD20, but have a look at the Quark123 before you buy it, available with an XP-G R5 or with an XP-E R2 as well (if still available)! It's beam is floodier on both models.
    My way : From Maglite and drop-ins over Fenix & Co to the real things - Customs and Titaniums!
    Flashaholic* yalskey's Avatar
    Jul 2006
    Baltimore, Maryland
    Oh yeah... you should do it for sure. The new version is like 11 or 12x better, at least!
    This will probably be your last light anyways... right? You wouldn't want to live with the regret of not having it when you really needed it.
    Besides, what's money just sitting there doing for you? You'll get much more use out of the light.
    Plus, the clip is made out of the same stuff Wolverine's claws are made out of, so you'll be able to pull a truck out of a ditch if it came down to it.
    (just some of the stuff that goes through true flash-a-holics minds to justify yet another light)
    *Flashaholic* Illum's Avatar
    Apr 2006
    Central Florida, USA
    depends on what your needs are, its not a light for everyone.
    If you find it to lack certain traits you desire, theres always BST
    Jun 2009
    Jo Daviess Co, IL
    Quote Originally Posted by Henk_Lu View Post
    As far as I know this new version only comes with the OP reflector and from what limited info there is out there on this one I've been told it still throws as well as the older version just with more spill added in. Also this is the same LED as what's in my D10 SP which has a pretty nice beam.
    I have checked out the Quarks but I don't really care for the pocket clip on them and the run times don't enthuse me either. Not to mention I would get this PD20 at a REALLY good price brand new!
    Quote Originally Posted by yalskey View Post
    Hint the sarcasm! Yep! This will be my last light........this month!
    Quote Originally Posted by Illum View Post
    So true! What I want is a small 1xcr123 light with tons of lumens, really good throw and a clickie switch for operation. Simple UI is a must! I'm not a techie so spending 20 hours trying to learn how to program my light is not an option. Right now my primary EDC lights are the D10 SP and Ex10 R2. I like how a light like the PD20 has a slightly more tactical feel as opposed to the PD drive of the Nitecore lights.
    Flashaholic* skyfire's Avatar
    Dec 2009
    Los Angeles
    of course you dont need it, im sure you have plenty of other lights.
    but if you have an itch that bad, go ahead and scatch it, youll feel better
    Does the PD20+ not have the new hybrid reflector like the PD30+?
    *Flashaholic* Sgt. LED's Avatar
    Sep 2007
    Chesapeake, Ohio
    Can't you find something newer to spend the money on?
    Jun 2009
    Jo Daviess Co, IL
    Quote Originally Posted by jhc37013 View Post
    I dunno! I guess I'll find out because I just pulled the trigger. What the hell! Good price = easy resale in the BST forums if it gets no pocket time. FWIW I picked this one up off Ebay from seller Fenixflashlight for $52 shipped. Not a huge savings but that's $10-$15 cheaper than anywhere else as far as I can tell.
    can i use diffuser tip with fenix pd 20 r2?
    Enlightened superpila's Avatar
    Jan 2009
    London (UK)
    Quote Originally Posted by alvin8803 View Post
    Unfortunately you cannot use the old diffuser with the new model.
    Anyway, here is a comparison I did sometimes ago
    http://www.candlepowerforums.com/vb/...d.php?t=250989
    Instaed of the PD20 R2 ,better check the PD30 R2..
    EDC: FENIX TK11 R2 & PD32 as a backup along with PD20+Fenix headband as EDC headlamp.
    Flashaholic* HIDblue's Avatar
    Mar 2010
    California
    If you miss your old PD20, just pull the trigger and get the R2 version. The pocket clip is really sturdy and the light stands up to hard use/accidental abuse. I've been pocket carrying mine for a while now and it still keeps on chugging. IMO, I think the single 123 form of the PD20 is perfect for pocket carry while a 2x123 light may be a little cumbersome for pocket carry, unless you wear cargo pants every day.
    If you want the same form factor but a forward clickie, check out the Lumapower IncenDio. It also uses 1x123 batt, has a forward clickie, is insanely bright (XP-G R5), but has a horrible pocket clip.
    I swap out the PD20 and the IncenDio for pocket carry, but the PD20 is definitely sturdier.
    My dog ate my flashlight...
