jk037
This may be something of a dumb question, but...
How does the efficiency of a high-powered LED (I'm thinking of 1000+ lumens here) compare to that of an incandescent light of similar output?
The reason I ask is that I have always believed LEDs to be highly efficient (this being their major advantage over incans, along with robustness and longer life), but it appears that the "power" LEDs still produce an awful lot of heat when driven hard.
So, does the efficiency advantage still hold true at high outputs, or does there come a point where a good incandescent bulb can produce more lumens per watt than an LED, and hence a longer runtime than the equivalent LED using the same battery capacity?
