Hi there, swiss first time poster here, glad to be here. How is everyone?
I'm sitting in front of my 18650 ME P7 flashlight (DX: sku 12060) with a driver that gave up yesterday, so I soldered for DD and measured the tailcap 1.5A @ 3.49V on a fresh 2600mah ultrafire.
I don't like DD, so I thought: why not mod the flashlight with 3x XP-G's on 20mm MCPCB and carclo optics from cutter, AW 18650 and a driver.
My question is: How can I get the most lumens out of the light and still be efficient? What driver would you suggest? The existing one has about 17mm diameter and is mounted in the heatsink, with a spring on it. I'd like to have at least 2 modes in order to have the option of longer runtime. I would only be on high for very short periods (i.e. for showing off), so I don't care about heat and runtime on high.
3x XP-G 20mm round is wired in series, so the driver should put out about 11.1V and 1A on high?
Or would you suggest 3x XP-G's on star, soldered parallel and drive at 3.7V 3A? would be easier to find a driver I guess
note: I'm confused if the driver should really put out 3.7v, cause Vf at 1000mA for one XP-G is around 3.26V.
eah die at 1000mA would give around 350lumen without temp. losses, so theoretically 1050 emitter lumens!
Please forgive if I made some mistakes, your help is very appreciated!
Achim
Achim
