XD9
- Joined
- Dec 21, 2008
- Messages
- 302
I have a Costume High CRI Light. I order the Executive... One thing I notice is that there is no momentary on. How can I enable momentary on in the Executive?
Thanks!
Thanks!
While the subject of momentary mode is up for discussion I wonder if any can tell me how to set the brightness for it? I've been able to easily adjust the other 3 modes, but not the momentary high brightness setting which I'd like to dial back either one or two levels.
Well after lots of reading I realized I've been calling the Forced mode Momentary. Now have Momentary enabled, but can't figure out how to change the brightness of either Forced or Momentary, so I'll keep after it!
Sorry but I forgot all about it! All I want to do is to lower my highest forced setting by one level, but my battery life is so great that I hardly care anymore. :twothumbsI've given you one month to figure it out for me. Did you do it yet?
Might be worth downloading the latest version of the Clicky Users Guide. Force Setting is now called Turn On Preset, which makes a little more sense.
The way to understand momentary on is that when you press-hold from off, the light will come on at whatever level as it would have done if you had simply clicked to switch on. This will either be your selected preset level (if you have Turn On Preset enabled) or at the last level used if T-O-P is disabled.
If you enable T-O-P you can choose any of the four levels as your preset level, and this will also be your momentary level. Additionally, Click-PH from off will give you momentary operation at the Primary setting. This means that you can have direct access to two momentary settings if you want.
Thanks for both of these informative posts and I finally understand the UI enough to program it to my liking!Kaichu Dento, CLBME,
I think there is confusion between momentary from off and the momentary use of preset level A. They are very different. Momentary from off is a feature that can be turned on and off in the option menu and only affects what the light does when it is turned off.
When the flashlight is turned off and the momentary feature (option) is disabled (off), a press of the button for any length of time will turn the light on and leave it on when the button is released. However, when the momentary feature is enabled (on), a long press of the button - over 1/3 of a second - causes the button to act in a momentary fashion. That is, when the button is released after being pressed for over 1/3 second, the light turns off. Nothing more and nothing less. Remember: the momentary feature only affects how the light reacts when it is being turned on. Once the light has been turned on (with the button released) it has no further affect.
The momentary use of preset level A (High on the executive models) - press and hold when the light is turned on - allows you quick momentary access to preset level A from any other preset level. Release the button and you return to whatever preset level you were using before you pressed the button. The action always happens and is not affected by the setting of the momentary feature discussed above.
Preset level A can be selected ("latched" - i.e., made to stay on) by a click, press-hold-release. See page 3 of your manual. If you want to modify preset level A, you must start by selecting it with the click, press-hold-release command before you select a new brightness level from the Brightness menu. In a similar fashion, if you want the select preset level A as the default turn on level, you must first select it with the click, press-hold-release command before selecting the Turn On Preset option (i.e., the forced turn on setting) in the Option menu.
MoonShadow has it correct. My post is just a bit more detailed.
Henry.
Henry.
