I am planning on using a Mag 2d to mod into a triple r2 light(on a tight budget also, due to being in college). My first question is whether 3 p60(26.5mm) modules will fit into the Maglite head?
I want to use these leds.
http://www.dealextreme.com/details.dx/sku.15943
These reflectors for maximum throw.
http://www.dealextreme.com/details.dx/sku.5937
And this driver.
http://www.dealextreme.com/details.dx/sku.26106
I plan on using two quality 2500mah 18650 batteries in series, and was wondering if this would work. Also, since the driver says it is for 5 leds, will running 3 leds in series overdrive the leds and burn them out? And if it does not the specs say it runs each led at 800 mah, will this achieve near maximum output without jeopardizing the leds, or should I look for a 1000mah or 1.2 amp driver( I have little knowledge in this area)?
Thank You
And this driver.
Thank You
