AlphaZen
I have one ordered and would like to know what your thoughts or impressions are of this light. :thanks:
The light that's out now, with the warm tint and the 3 levels, seems very appealing. What is the quality like on these small Dereelights?
I have the XPG version, love it. Deree doesn't get much hype or excitment as other brands, but their design is solid and their components are high quality.
I had to use the very tip of my thumb, and then still it would slip out of my hand because of the pressure required. Too recessed and too stiff.Why is it hard to operate? I think mine is fine..
Thank you so much for this solution.:bow: It is working beautifully now. Slight wobble during the tailstand, but worth it for an easy clicky. This is a VERY NICE light!I did slightly modify it to make it more responsive. I got those round foam black pads you can put under furniture, shelves, etc. They are a couple millimeters thick, and I cut a small circle off of one. Then took out the tail switch, peeled off the self-adhesive on the back, and stuck it to the tailswitch.
This way the tail switch needs to travel less before the light is turned on. I do this for a lot of lights.
