Re: Which RA CLicky should I choose?
The 170 cannot be set at 140 lumens. The next lowest level (10 secs afer the burst) is 120 for the 170, and 100 for the 140, according to the manual. Each can be set as well at these levels.
To me, the differences are negligible and proportionate (although the 140 drops 10 lumens less). In other words, there is a difference in the 170 and 140, but output (observed brightness) is not the most noticeable difference, since the burst feature leaves each running at a 20 lumen difference on max after 10 secs.
I am describing the 140Gt which is a wide beam, and 170 (which is only in narrow). These two Ra lights are the same price. Less difference would be noticed I'm sure (no experience with this) if both beams were the same narrow beam, GDP emitter.
Tint and brightness are independent, and not necessarily objective values...Perhaps one is more important, but the 170 is also more efficient at a given power level; that is, it produces either more light at the same power level or it produces the same amount of light longer, depends on how "efficiency" is being defined I suppose.
I really liked my 140gt, and think that it is Ra's best product, but found that the throw of the 170 (because it was both narrower and slightly brighter) won out for my needs. I could not keep both... If I was considering either the 140 or 170 narrow, the price difference would make the 170 a hard sell. If I did not need throw, (narrow option) the 140Gt is far and away a better light to see things with in the dark to my eyes, but I won't be able to see things as long with either 140 as with the 170. I have a Novatac 85 that has a beam tint that I prefer over the Ra 170, and is very very close to the 140Gt, but the run time for the 85 at max is lower than the run time on the 170 when set at 85.
edit... I seem to have gone off on a tangent here, the OP was asking about window material... I'd skip the sapphire, the glass is fine, depending on your use of the light, I'd focus on the 140Gt or 170 question...spend the rest on batteries
