Anyone know anything about Linux?
SmurfTacular
Orange County, CA
Because if you do, you would be the nicest person in the WORLD to help me out here.
Long story short, last semester I missed the second to last day of school. On that day the instructor gave out the final (the only test in the class). I missed it. So about a month later I check my grade and my grade was "IF". I was like wtf... so I emailed my teacher and he said I need to submit this test. Problem is I knew literally nothing about linux when i took the class, and I barely knew anything after the class.
I would do anything for you guys to help me, even money through paypal. Please dont see this as spam.
Part two of the Final will be posted on BlackBoard and emailed to everyone by this
weekend.
QUESTION 1
Which of the following file system types causes the least impact when upgrading an Ext2
file system?
A. Ext3
B. ReiserFS
C. JFS
D. XFS
E. VFS
QUESTION 2
In the past what has been (and still is for many releases) the most popular file system
choice?
A. ext2
B. bsdf
C. jfs
D. ext3
QUESTION 3
You have a Linux system with a 100GB ext2 partition containing large amounts of data.
To minimize the boot time, you decide to convert it to a journaling filesystem.
Which journaling file system would be easiest to convert the partition to (without
destroying existing data)?
A. resiserfs
B. vfat
C. ext3
D. xfs
QUESTION 4
Assuming that your system is not configured to display the current directory in either
terminal or the run command and you need to find out the name of the current working
directory. What command or tool should you invoke?
A. whoami
B. curr
C. file
D. pwd
E. dir
QUESTION 5
What two things does the /etc/fstab file contain references to?
A. File Systems
B. Mount Points
C. User Options
D. File System Defaults
E. File System Permissions
QUESTION 6
How many Primary Partitions can the standard Linux system support?
A. 1
B. 2
C. 4
D. 8
QUESTION 7
What type of Linux partition is one with the designation "82".
A. Root
B. Primary
C. Swap
D. Extended
QUESTION 8
What is Journaling?
A. A way of channeling data to the processor.
B. A new way of converting data to the assembly level.
C. System management techniques to layer channels of data threading.
D. A method used in many of the newer partition types to keep track of file locations for
faster recovery.
QUESTION 9
What run level represents basic GUI multi-user?
A. 1
B. 2
Fundamentals of Linux - CIS A109, Fall 2009, FINAL Part 1
Due: 15, December 2009, in person
C. 3
D. 4
E. 5
QUESTION 10
When you create a new file, the permissions show as 654. Assuming the normal mode
setting what value is the umask likely set at?
A. 0012
B. 0002
C. 0123
D. 0022
QUESTION 11
You want to view a listing of previously entered commands. What command would you
use?
A. hist
B. histfile
C. showbuff
D. history
E. whatshapnd
QUESTION 12
Which of the following are executed ONLY during a Login session
A. /etc/profile
B. /etc/bashrc
C. ~/.bashrc
D. ~/.bash_profile
E. ~/.bash_logout
QUESTION 13
Where would you find the first IDE drive in a system?
A. /dev/hda
B. /dev/sda
C. /sys/hda
D. /sys/sda
QUESTION 14
Which of the partition systems listed use journaling? Choose all that apply.
A. ext2
B. ext3
C. ReiserFS
D. XFS
E. JFS
F. VFAT
QUESTION 15
Permissions in Linux are based upon a 10 letter design called the three triplets. Now three
triplets equal nine, so what is the 10th character used for?
A. Defines the umask.
B. UID of the files owner.
C. Identifies what type of object the permissions are relating to.
D. Specifies which set of rights are dominate.
QUESTION 16
What file does init processes use as its control file?
a.
/etc/proc
b.
/etc/inittab
c.
/etc/initproc
d.
/etc/init
QUESTION 17
Which of the following directories would be the least likely to need backing up? Choose
Two.
A. /usr
B. /etc
C. /home
D. /tmp
E. /swap
QUESTION 18
Which of the following will copy file1.txt to file2.txt? Choose Two.
A. cat file1.txt > file2.txt
B. cat file1.txt | file2.txt
C. cp file1.txt > file2.txt
D. cp file1.txt file2.txt
E. cpio < file1.txt > file2.txt
QUESTION 19
You need to display all files in the current directory that start with a "t" and end with a
"b", regardless of their length or use of delimiters. Choose the best answer.
A. ls t*b
B. ls t.b
C. ls t-b
D. ls [t-b]
QUESTION 20
You want to view the top 20 lines of a file which switch with the command "head" would
allow you to do this.
A. -top20
B. –n20
C. –t20
D. –u20
QUESTION 21
You have partitioned your hard drive into nine segments. Which of these can be logical
partitions.
A. 3-9
B. 4-9
C. 5-9
D. None of above
E. All of them
QUESTION 22
What option can be used with the shutdown command give users 5 minutes and warning
message alerting users that the system will be shut down?
A. shutdown 300
B. shutdown 5
C. shutdown -300w
D. shutdown -5w
QUESTION 23
What option can be used with the shutdown command to cancel a pending shutdown?
A. shutdown -u
B. shutdown -x
C. shutdown -n
D. shutdown -c
QUESTION 24
Which program will allow you to change the priority of a program already running?
A. top
B. nice
C. niceit
D. renice
E. chnice
QUESTION 25
What daemon controls the syslog?
A. syslog
B. syslogd
C. logd
D. sys
QUESTION 26
What command be used to find the systems previous run level?
A. runlevel
B. level
C. rlevel previous
D. show level previous
If anyone can answer ANY of these, that would be AMAZING
Popsiclestix
I'm not sure of the ethical and moral implications of giving you some answers, it seems to me that this is a test and it's purpose is to test your knowledge of the linux operating system.
But I do suggest Googling some of the questions. The answers are fairly easy to find.
You may also want to login to a linux system via SSH and try some of these commands to see if they're valid ;-)
_Shawn_
CO
Just took the test. 'man' that, was fun.
I got a 95%. Used Google to check my answers. Then scored 100%.
Thanks.
:poke:
carrot
New York City
That was easy enough... however, you gain nothing by having us do the test for you... you're just cheating yourself.
TorchBoy
New Zealand
I also see a problem here. I don't think you should pass a test if you still know nothing about the test subject material after "sitting" the test.
I would do anything ...
Like quickly researching the answers? :) Give it a go; learn something on the way.
SmurfTacular
Orange County, CA
Thanks for the advice, but unfortunately I cant boot linux. Every time it attempts it just restarts and its driving me crazy. And google hasn't helped much either.
And I get your guy's side of the argument, If I cant complete it myself, then I shouldn't pass. I guess I'll give google a 2nd chance. Its really hard for me considering I cant boot linux :(
Whatever, thanks though :)
Max_Power
San Francisco Bay Area
Something tells me you missed more than the one day of class.
Trying to get someone else to take the test for you defeats the purpose of taking the class. The intention of this class was to get some basics into your head for the next class to build on. Without the foundation to build on, you are going to find it very difficult to comprehend the next class.
Using Google to find the answers still seems like cheating (yourself), but at least you will know how to look stuff up. And with luck, maybe you'll learn something in the process.
Popsiclestix
I'm not sure if looking on Google is cheating himself really. I wouldn't know half the answers to this unless I looked it up and I've been using Gentoo for 3-4 years now. The first couple of questions seems to be a history lessons (really? who even cares about ext2 anymore unless you're working IT at some company still on ext2). When I need to look up a command it's a quick trip to "man <command>" followed by Google if that fails me (or the information is a bit dense)
It's not like you have to sit there for more than 2-3 minutes to figure out the answer to each of these questions.
But of course, hands-on experience is the best way to internalize all this material, and something tells me that this was an operating systems course and he somehow managed to get all the way to the final without learning the command to get the name of the current working directory (Question 4)
SmurfTacular
Orange County, CA
This was literally the only actually assignment. The only other grades where based on participation. (and a few quiz's after guest speakers). But that was it.
And I'll plead guilty for missing more then one day :oops:
I took the class in hopes of learning how to use Linux, but it seemed as though everyone in the course already knew a lot about linux, so the instructor just jumped right into the advanced stuff...
KD5XB
DM84jk
The only thing I know about Linux is that I tried it once and it was confusing as he||! :green:
carrot
New York City
have you tried booting a live linux cd ?
This. The new Ubuntu CD's are an excellent live environment, although for your needs all you have to use is a simple distro like Damn Small Linux. If your computer is powerful enough, you can just run Damn Small Linux in a QEMU window (type of virtual machine) on your Windows machine, and then you can do at least half of this yourself with ease.
gadget_lover
Near Silicon Valley (too near)
I think that the main point to be taken from this thread is as Max_Power said:
"The intention of this class was to get some basics into your head for the next class to build on. Without the foundation to build on, you are going to find it very difficult to comprehend the next class."
This is true of every class, and it's why you should never take a class just to pass it. They provide the background and context for understanding related subjects.
The last time I attended college classes the students were clearly divided into several groups, with most just there to pass the course and get the credits. They struggled because they had done the same with the prerequisites, so were not prepared for the course material.
To the OP: If you can not pass the test, then it's time to take the course again and pay closer attention this time. If you can't learn it, then it may be time to assess your background or course choices.
Daniel
gadget_lover
QUESTION 26
A. runlevel
B. level
C. rlevel previous
E. who -r (works on all posix compliant UNIX derivations)
A. whoami
B. curr
C. file
D. pwd
E. dir
F. echo $PWD
Thirty years ago I was taught that there are a dozen ways to go just about anything in Unix, and that most of them are perfectly acceptable.
Daniel
Ragiska
you mean it was the only assignment for a grade. there is still no excuse for not participating in the recommended coursework and reading assignments, even if it was not explicitly for a grade.
you mean like just about all of them?? :whistle:
LEDAdd1ct
Hudson Valley
I've been in spots where I didn't know the answers, too. But as both a student and educator, I feel like there is something very wrong about this. Just my two pennies.
luckybucket
I actually loaded Linux on a third computer just for fun. The learning curve is as steep as I thought it would be, but I love it so far.
h_nu
Virginia
I could probably answer most of these without ever having taken a course. All I do is play. :)
Before you retake the course, research live CDs (start at Distrowatch). Several small versions will run in RAM as well as from the CD. Try a few.
Get Moba Live CD. It will run a small iso file of the live CD from within Windows so you can use Linux like a program in Windows. It's a front end to QEMU and it will even run from a flash drive.
Get Virtual Box and install Linux into a virtual machine. That will give you practice with the install procedure.
Plan your next attempt now and ask questions during the course. Someone in the class would probably like to help.
