I have a love/hate relationship with my JET-III ST BVC. I love it's size, low lo, high hi and hate that I so easily enter program mode and mess it all up.
Does anyone know a way to disable the programming feature of this light? I've got my three levels set and would be thrilled to eliminate the programming feature. Is there a standard chip, or circuit, or part which I can break, cut or remove to eliminate the programming?
Any help is appreciated!
I just received a Jet III Pro ST with the R2 and BVC and could not get it to program or function properly. I would program the three IBS modes, but then turn the light on and it would be in Strobe, which wasn't programmed, or it would come on in a low-low which also wasn't programmed. I kept resetting the light to the factory default and trying to program it. But, it seemed to have a mind of its own.
I posted a thread:
https://www.candlepowerforums.com/threads/262679
and received a couple of suggestions, as well as contact from Flavio at BugOut where I purchased it. However, in the interim I noticed that my tail cap wasn't completely tightened and there was another post about using longer times between the program steps.
https://www.candlepowerforums.com/threads/259805
Between tightening the tail cap and waiting longer between mode settings, my light is now working perfectly. Hopefully, that will continue to be the case.
Additionally, others have suggested that there were problems with the clicky switch so that might be another option to explore.
It's a great light, when it's working properly. Good luck.
