I don't think it's possible, although I'm sure you can order a sheet of pyrex cut to the specifications on some chemical site and retrofit it...I don't believe Surefire sells Pyrex lens replacements, as the entire bezel must be replaced on a Pyrex light if the glass cracks or shatters. Pyrex gives you advantages in terms of about 7% more light transmission compared to Lexan (88% to 95%), so it will be a noticeable brightness increase, and Pyrex is resistant to heat, so it will not melt. I also believe it is far more scratch resistant. However, Lexan is resistant to impact and is pretty much indestructible.
