I am currently in the proscess of building a flashlight using seven cree xp-g R5 bin LEDs, and seven Tenergy 3.7v 2600maH Li-ion cylindrical batteries.
I am a little confused on the information I have been reading on the specs of the LED. I want to run all seven at full brilliance(I think 1amp?). So if there forward voltage is 3.2-3.4V and I hook up the LED to one of my batteries along with a 2W 2ohm resistor is the LED going to get the full 1 amp? I guess what I am trying to say is will an LED use full amperage strainght from a battery or do I have to use some sort of driver to push it to full brilliance?
Also I am not sure how to configure my cells? I heard parallel is not a good way because of charging issues. Should I series them for a higher voltage?
I am kind of confused, so any help would be nice.
1. How should I configure my battery pack? What voltage to use?
2. Use resistors or an led driver that will handle seven xp-gs at 1 amp?
3. Also how to configure my leds?
