PaulW
I ran some tests of some of these super bulbs to compare them with SureFire performance. There has been a question in my mind of just how many lumens are generated by the various home-brew configurations that some of us interested in Mag mods have been talking about.
Part One of the tests was the measurement of relative brightness. I used fresh batteries for each of the configurations. I shone each light against a wall and measured the reflected light with a Wavetek LM631 light meter. Ambient levels were between 0.06 and 0.11.
This kind of test tends to measure the overall brightness of a light and approximates the total lumens put out. Lights with narrow beams (with Mag reflectors) have an advantage and will register somewhat higher with respect to those that have more spill (like the Tigerlight textured reflector).
Part Two was measurement of performance outside of the host. I moved batteries and lamps to my breadboard where I could measure voltage and current at the same time.
Shown in the chart below are:
<ul type="square">[*]Host that the lamp is in
[*]Lamp assembly or bulb
[*]Battery configuration
[*]Lux measurement -- a relative indication of brightness
[*]x30 is an arbitrary multiplier to suggest Surrogate Lumens
[*]Advertised lumens by SureFire
[*]Volts measured on breadboard across lamp under load
[*]Amps measured on breadboard through the lamp
[*]Watts calculated (V * A)
[*]Amps measured while lamp in host
[/list]
Host____Lamp_______Batts_____lux__x30_Adv___V____A___W__AinHost
Mag2D___TL texturd__2x3x123__4.80_144______8.2__2.08__17
SF_M3___MN11________3x123__8.76_263_225__7.2__2.60__19__2.52
Mag2D___WA01185___2x4x123_12.59_378______9.9__3.18__32__2.65
Mag2D___Carley809___2x4x123__5.92_178_____10.9__1.22__13
Mag3C___WA01318__4x123+AA_11.59_348_____10.6__2.00__21__1.93
SF E2e___MN03_________2x123__1.80__54__60__5.3__1.12___6
SF E2+___P61__________2x123__3.72_112_110__4.4__2.44__11
SF L4_________________2x123__2.28__68__65
SF A2_________________2x123__1.84__55__53
The WA 011185 did not live up to the expectations I had. I discovered that the reason is unwanted resistance in my host at high current levels. The current in host is much less than on the breadboard, where I have taken pains to make low-resistance connections. Note that the degradation of current for the SF M3 and in the Mag3C is less severe. I believe the problem is due to the hurried job I did of constructing an adapter to allow two parallel stacks of 4x123 in the Mag 2D.
This is what I have measured. I leave the fun of analyzing it to you. I have found that an inspection of the value of Surrogate Lumens per Watt give rise to some interesting ideas. Any analysis is helped by knowing that:
<ul type="square">[*]The values for load voltage are not precise. On fresh batteries, voltage plummets fast.
[*]The values for current are much more stable.
[*]Surrogate Lumens is an arbitrary number derived from comparative measurements. Anything derived from it will also be relative.
[/list]
I must mention that Ginseng was of immense help in doing this. He loaned me the WA bulbs. But far more than that, he has been a welcome source of information, ideas, and advice. Thanks a lot Wilkey.
Paul
[/list]
[/list]
Paul
