Fenix L2D problem: Flickers, inconsistent power on
lilxboi
Wondering if anyone else has had this problem or knows a fix. Just recently the light has seized to be functional. The light does not turn on consistently or switch through modes well. At times the light will shut off when changing mode and I would not be able to turn on the light consistently. Sometimes I could press in the clicker slightly and it might have the light turn on for a second or so. That or the light doesn't power on at all at times.
I've cleaned the light and taken apart the tailcap and cleaned as well to no success. Any suggestions or is this a known issue?
Thanks.
John_Galt
SW, PA
Clean the contacts in the head, tailcap spring, and the threads, etc. Gunk may be building up, and causing intermittent contact.
