shankus
Have any of you done this, or toyed with the idea?
The idea is to machine a second o-ring channel in the barrel of a Mini-Mag, just aft of the head seal o-ring, such that, the two o-rings together might stop the notorious Mini-Mag head wobble by stabilizing the head in the longitudinal axis.
I was thinking of this as a fix for the focusing mis-alignment/wobble while using a high dome luxeon on a MadMax+ sandwich, with NX05 colimator.
I think if the o-rings are lubed, it would still turn fairly easily.
I always peel out that o-ring, and clean the o-ring, the channel, and inside of the head with alcohol. This is how I leave Mini-Mags that have the NX05 in them. There is no need for focus, but I do remove the head occasionally for candle mode, so not much of a problem there.
Now for a Mini-Mag that will be used to focus, this is a bit much, but it gets me to a starting point to re-lube, very meagerly, until the head turns easily enough for use, but not so much that I think I might lose it, or have to re-focus it for each use.
The C & D cell Mags have that finer thread, and it seems, closer tolerance of manufacturing that keeps them at the focus you left them with, but the Mini-Mags are much looser.
The other complaint I have with the Mini-Mag/LED mod combination is the head screwing down too far, and turning the light off.
This might fix that as well, if left unlubed. It might have enough tension to keep the head from moving.
On one of my MadMax+s, I am going to use the 2 AA series brass collar & button as a stop for the head, in addition to being a mode of carry for the light.
If a small dimple is made in the barrel of the light, where the set screw touches it, the collar will neither rotate nor slide, and will make an excellent stop.
