I have an Olight T20 Tactical and a Quark 1 x 123 and 2 x AA, in the tactical format. While I haven't tried the Olight "I" series lights, if the I20 has the clicky that also puts you into strobe mode, I'd get the Quark 2xCR123 light. The plus in my opinion for the Quark tacticals is that you can set the two levels you want to use, and you don't have to worry about changing through unwanted levels. I've also found that I prefer the Quark beam profile to that of the Olight, which has a very bright sharply defined center spot. It's not bad, and throws well, but I just prefer the wider spot and smoother transition of the Quark beams.
