McAllan
As a tech geek I couldn't resist investigating my new MagLite XL100 as much as I could without disassembling it.
I found that from the bottom of the pill it looks very much like the Rebel MiniMag but not the Luxeon. The top side with the LED too but with the writing -091 instead of the -090 on the MM.
I also discovered that the pill only has two electrical connections to it - the power. This means that it's the tail cap doing the power switching. I believe this is also the case for the low PWM frequency (though upped a little from the MM) since the buck/boost regulator can't keep up with higher frequencies. An alternative would have been 3 wires - two for power and one for signal when the LED should be on.
Try connecting a (low cost) speaker or headphones to the top of the battery carrier while holding the bottom to the tail cap and operate it. Some quite interesting sounds it make. Especially with partially drained batteries since there will also be a slight amount of (almost) unnoticeable PWM regulation on full power. Nitelite or power adjusting on Dim is particular interesting and melodic.
Finally: Has anyone dissected an XL100 yet? Disassembled the pill and tailcap?
I won't do it with mine as they're quite expensive here compared to US (but still a need to have for a geek ).
