LED_ASAP
A casual shopping trip at WalMart turned out this Garrity pen light---stainless steel body double AAA light with a clicki.
Well, I am totally spoiled by the pure white Luxeon Star light and can't stand a yellowish incandescent beam any more /ubbthreads/images/graemlins/smile.gif A quick measurement of the light body indicates there is 1.6cm available space for a potential LS mod. I wanted to use a HD plus a Solitaire reflector for a decent beam, which takes up 1cm---leaving me 10mm diameter and 6mm height to squeeze in a booster plus the heat-sinking elements /ubbthreads/images/graemlins/thinking.gif
Two nights later, I got something that could well be the brightest pen light to date /ubbthreads/images/graemlins/cool.gif Here is the completed light:
If I just use a plain glass cover, it's flood beam with a decent hot spot.
The beam is slightly irregular because the reflector is distorted a little in the assembling process /ubbthreads/images/graemlins/crazy.gif But unless you shine it to a white wall, you probably won't see the artifact in real use.
Alternatively, add a 1/3 acryllic ball to make a tighter beam:
Now the beam shows the square image of the Luxeon die:
Compare it side by side with an Arc Grey kit with P1H:
If you wish, add a 1/2 acryllic ball to get an even sharper beam:
You will see a smaller and much brighter square:
Again, compare it to the Arc Grey:
It drives a Q4H HD at about 400mA The total light output, therefore, will be comparable to, if not more than, a typical BB/MM in MiniMag /ubbthreads/images/graemlins/grin.gif The battery draw is 600mA, which means a little more than 1h run time on Ni-H's. When the battery voltage drops, it will drop into moon mode.
Heat is a big concern for a light so small while so powerful. The head section becomes significantly hot after a few minutes' use /ubbthreads/images/graemlins/wink.gif Holding the light by the head section should help the heat dissipation.
