FNinjaP90
- Joined
- Jan 8, 2003
- Messages
- 888
Hello, I have an E2e with the P61 lamp but the beam is too wide. The beam angle is about 16 degrees with the P61 and about 11 degrees with the MN03. I want to try to get it under say..7 degrees. Does anyone make a convex lens in the E2e or Minimag size (22mm diameter, height less than 2.5mm to accommidate the larger P61) that will allow a tighter focus of the beam?
