ho71ko,
With all due respect, I am right. I have dissected an L1 and how I described it is the way it *does* work, unless Surefire made major changes to their design.
Sorry to burst your bubble but it is by no means "state of the art". It is a clever mechanical means I must admit. The way it works is that with the series resistor in the circuit, the boost regulator is running wide open, with the resistor providing the current limiting (actually, it drops the voltage) to keep the boost converter out of regulation. WHen the resistor is bypassed, full current from the cell can now drive the circuit into full regulation. There is a difference in runtime between high and low precisely because of this resistor. When in low beam, the current drawn is very low compared to full regulation.
I don't know where the idea of using different anodizations to realize a resistor came from. It is not a process that can be controlled precisely, not to mention a very expensive one. Why not just use an SMT resistor (just like Surefire did) Also the electronics in the head has absolutely no intelligence whatsover. In principle it works just like any other boost regulators. Only in the L1, the circuit is mostly controlled by HC04 type inverters which can be had for pennies. It doesn't use a monolithic IC controller (like the ones from Linear Tech, Maxim, National etc.) like most other LED regulators. It is a very cost effective electronics design. So despite what most people would like to think, that there is some "magic" going on in there, it is all very simple. Hey, if you want to make $$ with a product remember the KISS principle. There is also a certain amount of elegance in being able to implement a seemingly complex task using the simplest solution possible. /ubbthreads/images/graemlins/smile.gif
