This is a mostly "for fun" thread, since I'm already bugging Milky for a Triple XP-G mod. Though I suppose it would also be kinda useful as an alternative especially considering the current availability of said mods(Moddoo, custom Tri/Quad XP-G builds), and obviously high price tags.
Here are the criteria:
-Must use an LED emitter(I have a list of reasons I won't get into for wanting this).
-Minimum of 1200 lumens out the front.
-Minimum runtime must be at least 15 minutes.
-Body must not be thicker than 32mm(1.26 in)
-Body must not be longer than 165mm(6.5 in)
-Head must not be larger than D36 size.
-Total cost must be less than $300(rules out any custom work).
-Must retain at least 1000 OTF lumens for at least 2 minutes.
I figure the easiest thing to do would be to drive an SST-90 at about 5-6 amps to avoid damage, loss of lumens due to heat, and keep the runtime higher. Heatsinking could be problematic, but I figure lots of AS5 and copper tape would be a cheap fix for that.
However, there are a few other parts that have me stumped. I get that I'm going to need an SST-90 direct drive and an IMR battery for the high amperage, but I feel like there's definitely something more I missed. I have this nagging feeling that just because somebody sells a drop-in that's direct driven doesn't mean that all the power of the battery just goes through it instantly. I then hear things about modifying the springs and wires to lower the resistance. It's right about there that my brain short circuits and my eyes glaze over
